Crankcase scavenging mandatory?
Old Nov 20, 2008 | 05:06 PM
ayousef's Avatar
Default Crankcase scavenging mandatory?
How bad is it if I don't fiddle around and install a crankcase evacuation system on my TT Z06 (drysump FYI)
Can we understand the advantages vs disadvantages (basically the consequences of not having a crankcase evacuation system)
Please speak in english, cause this sounds like chinese to me
PS. disregard the title I meant evacuation.
Old Nov 20, 2008 | 06:26 PM
Monello's Avatar
bye bye rear main seal
Old Nov 20, 2008 | 07:15 PM
EPP's Avatar
EPP
I agree, there is going to be a lot of pressure in there, rear main seal, front timing cover, etc will all more than likely become leakers. Bob
Old Nov 21, 2008 | 12:01 AM
trey04gto's Avatar
Yes!!!!! Make sure you have good vacuum for the crankcase... I blew out 2 rear mains before I learned my lesson
Old Nov 21, 2008 | 07:24 AM
topend's Avatar
just put breathers on the engine your drysump should take care of the rest.
Old Nov 21, 2008 | 07:35 AM
ls1290's Avatar
Dumb Ass Vette Moderator
If you are making big power, a scavenging system is a must. Just breathers are fine for the 600 to 700 rwhp range. Anything more than that the block is start to have more pressure than what breathers can release. Remember the breather is a filter and a restriction.
Old Nov 21, 2008 | 09:30 AM
ayousef's Avatar
my previous 620rwhp SC C6 Z06 ran fine for about 15,000miles of HARD driving with no issues, until it crashed into a wall
Sorry am really clueless about this, but how do I know when I need a better crankcase evac. system? Does looking at how much vaccum the car makes at idle, partial throttle answer this question perhaps?
Old Nov 21, 2008 | 11:27 AM
ls1290's Avatar
If I was doing a "427 Warhawk + TTiX @ 15+ PSI boost", I would do a scavenging system without a second thought.
Old Nov 21, 2008 | 05:42 PM
ayousef's Avatar
I understand, but how does one assess how good is his crankcase evac system working, does a boost gauge tell anything?
Old Nov 21, 2008 | 06:06 PM
Monello's Avatar
You can hook up a vacuum/boost gauge to one of the nipples on the valvecover.
When you are WOT if you see any boost in there, then you have a problem.
I have hooked up both of my valvecovers to a catchcan, then to the turbo intake.
So when the car goes WOT it pulls vacuum from the valvecovers.
