Stupid question needs an answer
ALL else equal, what happens to a turbos A/R if you machine the exhaust flanges on both the turbo and turbo manifold and make them a little bigger
Would that reduce the a/r ratio?
A smaller AR will increase exhaust velocity which in turn will increase spool up times but it can build unwanted back pressure if not sized properly.
If you need a specific AR size I would recommend contacting Jose@forcedinductions.
Im sure he can help you get anything you need turbo related.
Goodluck,
Derek
Goodluck,
Derek
lol.I dont want to modify the entire turbine housing area, I just want to make both the manifold and turbine housing flanges a little bigger.
Again, I dont know how would that effect the performance based on what im looking for, ill have to research and ask, anyways if I do this it will be at a later stage
The turbine housing is essentially a nozzle so unless you were able to open up the entire area of the nozzle modifying just the inlet will not decrease the restriction.
Anyways, ill see how much power the kit makes, am sure it will be plenty, but im just a pain, I wanna make sure I do see the 1000rwhp magical number, at least on the dyno (bragging rights lol)
