another pcv/ catch can question
Old Nov 30, 2008 | 04:34 PM
extremetoy's Avatar
Default another pcv/ catch can question
would it be a good setup for a boosted engine to just completly cap/ not run the pcv system and run two -10 or -12 bungs/ lines to a vented catch can? what will this to do engine life?
thanks, Gary
Old Nov 30, 2008 | 04:47 PM
Monello's Avatar
It will decrease the life of your oil, as you wont have anything sucking out the bad stuff from your engine.
You really need to get a vacuum source setup to pull from the covers.
Bascially same concept as your, with blocking everything off and running 2 hoses to a catch can, but then running another hose from the catch can to a vacuum source, preturbo, like the intake filter, or the side of the turbo inlet.
Old Nov 30, 2008 | 04:52 PM
extremetoy's Avatar
so running the 2 -12 lines. one from each valve cover, to a catch can. then run a third line from the turbo intake to the catch can... would it matter that the line would be really long as its a rear mount...
Old Dec 1, 2008 | 04:03 PM
extremetoy's Avatar
sounds good?
Old Dec 1, 2008 | 04:40 PM
Jontall's Avatar
Just cap (vacuum) it and run the vented can; I do and there's nothing wrong with my oil.
Old Dec 1, 2008 | 05:54 PM
Monello's Avatar
Have you sent your oil out to get tested? Or you just looking at it, and saying "Looks good".
