LS6 cam for turbo 421? or bigger
Old Dec 5, 2008 | 09:14 AM
Boosted1320's Avatar
Default LS6 cam for turbo 421? or bigger
I have seen some awesome results with this cam on here, Im building a 421 w/ L92 heads turbocharged, track/street driven hoping for around the area of 1100hp. Would the LS6 cam do it or hold me back at all or should I just get a cam bigger ground for turbos? Im just thinking the not so radical lift will be easier on the valvetrain increasing efficiency. ? Input??
Thanks.
Old Dec 5, 2008 | 09:18 AM
ls1290's Avatar
Dumb Ass Vette Moderator
The LS6 will work in a 421, but it is pretty darn small. I would got with at least a 224/230//578/588//116 for a 421.
Old Dec 5, 2008 | 09:27 AM
koolrayz's Avatar
Not to highjack but who does a good job of specing custom turbo cams?
I know who I like on the N/A and nitrous side but I am moving to the darkside and am not sure where to turn?
Old Dec 5, 2008 | 09:29 AM
ls1290's Avatar
PM Patrick G here and he will set up here
Old Dec 12, 2008 | 09:25 AM
Anyone else have any input? Why is the cam too small? Isnt there like 8 second cars running it?
Old Dec 12, 2008 | 09:31 AM
ls1290's Avatar
I do not know of any 8 second cars running one. The amount of duration is very small and will have a hard time feeding a 421 in the upper RPM range. It can be used, but it will not make close to the power of a larger cam. The bigger the motor, the more duration and lift is needed to feed it.
Old Dec 12, 2008 | 09:34 AM
dschmittie1's Avatar
I mean yeah it will work but when you have that much money is building a 421ci motor whhy would you just put such a baby cam in it. There would be so much more to be gained by doing something larger and that is speced for your application. You will need to run big springs on a boosted motor anyways so why not out a bigger cam in it.
Old Dec 12, 2008 | 07:29 PM
Super Speed's Avatar
Definitely go with something a little bigger, you have the cubes might as well use them
Old Dec 12, 2008 | 08:15 PM
venom ws7's Avatar
I think power will fall off very early with that cam what does LS6 cam peaks at 5000rpm???
Old Dec 12, 2008 | 09:04 PM
fenix999's Avatar
sorry-hijack #2. What about an LS6 cam in a turbo 6.0? How do you think that will work being its just a 364"
Old Dec 12, 2008 | 09:05 PM
fenix999's Avatar
dount that highly. 2002and up Z06's rev quite high (7000) and peak pretty high up in their rpm range. These motors love rpm...and that one of the reasons why they are awesome
Old Dec 12, 2008 | 09:49 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
The '02+ ls6 cam is working fine in my neighbor's Escalade with a turbo. AWD launches at 7#'s of boost have destroyed a 4l65 and two 4l80 transmissions. That being said, I don't know how much the cam is holding back power potential, because his fuel system is only good to 6krpm. I have a feeling that cam will be inadequate for much more than what his motor is doing now.
Old Dec 12, 2008 | 11:31 PM
GrahamHill's Avatar
Seems like you would want considerably more duration to help fill the cylinders more with that extra CID.
Old Dec 13, 2008 | 02:33 AM
cablebandit's Avatar
another vote for patrickG
Old Dec 13, 2008 | 03:50 AM
cjg454ss's Avatar
c6 Z06 comes stock with a cam similar to an MS3, an ls6 is way too small, heck an MS3 wouldnt seem that wild at all.
Old Dec 13, 2008 | 01:04 PM
Ms3 really wouldn't be a good turbo cam, PM patrick G he'll do you good
Old Dec 13, 2008 | 06:06 PM
BlackySS13's Avatar
My Ls6 cam works really nice for its application. No complaints.
