man, I was totally thinking of doing this aswell... How did you get your hole cut so nice? Did you cut the hole, then run the pipe to it? That is pimp **** dude.
I feel like I should be the only person to not like it. You know just to mix it up a little bit... but I couldn't cause it does really looks so badass!
basically you tape up the fender, draw the oval, drill a hole and use the thin blade saw to cut out the line. If you take your time it should come out pretty good and just use a dremel with the sand paper porting bit and clean it up nice nice.
Originally Posted by patriotformula
I wouldn't change at all what you have right now... that looks awesome!
thanks brother
Originally Posted by Mean Green z28
WOW! That's like the exhaust dumps in a Mercedes McLaren Supercar ... I like!!! AWESOME SETUP!!!
That was the idea bro ... If the benzo can have it, so can the chevy copper.
some one has got to hate and mix it up
Originally Posted by 1CAMWNDR
Oh that **** rocks
thanks
Originally Posted by Big Bird WS6
with those numbers. can i ask what boost you are running on the gt35?
For which numbers. I have made between 900-1130rwhp on the dyno. The higher numbers are pushing close 20psi on the dynojet.
