Synergy 2 step... HELP!!!
Old Dec 20, 2008 | 01:12 PM
z28boysteve's Avatar
Default Synergy 2 step... HELP!!!
So I just installed a 2 step and it works great... ALL THE TIME
The damn thing will not shut off.
Ive double checked all the wiring there is no chance in hell its bad.
All the LED indicators work correctly,
when armed the indicator flashes correctly, when the clutch is depressed the light turns solid, and when clutch is released the light correctly turns off. the tach signal light is green, the clutch led on the circuit board illuminates when the clutch is depressed, and turns off when its not.
HOWEVER the 2 step will not adjust, no matter where I set the dials it stays right at 3500 rpms... and the thing is ALWAYS on even though indicators show its not even when driving normally or never armed... 3,500.. once I removed the ground from the synergy box, the car was right back to normal
ALSO the reverse lockout will not let me into reverse when the box is installed, and the tachometer repeatedly stops working on the dashboard.
If anyone has ANY suggestions please just CALL me 254 449 2059 Im thinking its a defective unit.
Old Dec 20, 2008 | 04:02 PM
Blackbird's Avatar
why don't you just give Synergy a call and get some tech support?
www.synergymotorsports.net for contact info.
