my catch can setup
Old Dec 21, 2008 | 11:42 AM
extremetoy's Avatar
Default my catch can setup
would it be ok if i capped off all pcv ports (even ls6 valley cover) and ran a line from each valve cover to a single catch can then another line from the catch can to the turbo intake. should the catch can be vented. am I missing anything/ will this work good?
Old Dec 22, 2008 | 10:00 AM
extremetoy's Avatar
any help here?
Old Dec 22, 2008 | 12:57 PM
vandal0-0's Avatar
I ran a line from each valve cover to a vented catch can and also used one of Speed Inc. valve cover breathers in place of the oil cap.I didnt run a line to the turbo inlet and I havent had any problems as of yet.I used the outlet for the pcv to run vacuum to my bov.
Old Dec 23, 2008 | 12:24 PM
extremetoy's Avatar
should i cap off the ls6 valley cover and all other stock stuff is really what im getting at if im going to run the catch can/ vented covers?
Old Dec 23, 2008 | 12:32 PM
vandal0-0's Avatar
I would run a line from the LS6 valley cover also.
Old Dec 23, 2008 | 12:38 PM
cjg454ss's Avatar
i have a setup working damn good, i put an k&n breather on the pass. valve cover, capped the rear one. then ran the moroso crank case setup. it runs from the rear driver side valve cover to the exhaust pipe. at the end of a hard run it will pull oil out of the valve cover and smoke blue out the exhaust. works almost too good. im going to run a catch can now to help it out.
Old Feb 2, 2009 | 02:29 PM
cjg454ss's Avatar
ill trade you an ls1 intake for the ls6
