NGK TR8 info
Old Sep 28, 2003 | 08:24 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default NGK TR8 info
If anyone wants the part numbers they are:
R5724-8
7317 (stock number)
They come pre-gapped at .022. I do not know what they are OEM for.
I would NOT run these unless you gonna run a lot of boost, like over 18-20 psi. Until then TR6's should be fine.
Just an FYI to those who were curious.
Old Sep 28, 2003 | 08:34 PM
CHRISPY's Avatar
Default Re: NGK TR8 info
cool thanks for the info. I bet those suckers will foul pretty easily
Old Sep 28, 2003 | 08:53 PM
ChrisB's Avatar
Are you positive those are a resistor plug? I don't have a NGK catalog handy, but I seem to remember they weren't?
Old Sep 29, 2003 | 09:41 AM
S_J_H's Avatar
I ran non resistor champion s57c back when I was on the bottle. Cut back and non projected nose plugs.
Very cold plugs and would foul quickly on the street.
However, no resistors in the plugs had no issues with the pcm or even the radio while using stock plug wires.
Steve
Old Sep 29, 2003 | 11:50 AM
LS1Tech Co-Founder
I don't know Chris.
Steve I think I can lean out the idle and part throttle to get the plugs to work a bit on the street.
Old Sep 29, 2003 | 02:30 PM
Big Rick's Avatar
I run these plugs and so do Slomaro and another one of my friends with LS1's.
