Turbo Size Question
Old Dec 27, 2008 | 05:12 PM
vandal0-0's Avatar
Default Turbo Size Question
I put a Garrett turbo on my car awhile back and when I bought It the guy told me It was an 88.All I know about It Is It has a .96 A/R compressor houseing and a 1.08 A/R exhaust houseing.Exhaust outlet Is 5",the compressor inlet Is 5" and the compressor outlet Is 3 1/2 inch.How can I figure out the size of this.
Thanks
Brad
Old Dec 27, 2008 | 07:25 PM
VORTECFCAR's Avatar
Are you sure the compressor isn't a .69 A/R?
If so, it's probably a GT47.
Nick
Old Dec 28, 2008 | 04:52 AM
GTP PWR's Avatar
Thanks
Brad
same specs as mine..... mine is a GT45..........
Old Dec 28, 2008 | 01:27 PM
vandal0-0's Avatar
Nick
Ill double check to be sure.
Old Dec 28, 2008 | 01:38 PM
vandal0-0's Avatar
It actually says .95 inside the compressor houseing.
Old Dec 28, 2008 | 03:43 PM
engineermike's Avatar
Use an inside mic to measure the ID of the compressor wheel inlet at the wheel. This is the inducer size and will be 88mm if it's an 88.
Old Dec 28, 2008 | 05:56 PM
veee8's Avatar
47-88 uses a 6" inlet
