HELP: OverBoosting!! Not sure why??
I then took the waste-gate covers off and found a large blue coil on the LH side and a bit smaller red coil on the RH side. I would think they should be the same but I"m no turbo expert. Then I proceeded to cut the springs in half to reduce the tension to try to get a change in the boost levels and much to my dismay, it did not seem to change anything when I test drove it again. What can I do to troubleshoot from here or did I just need to replace the waste-gates or the internal diaphrams? Thanks for your help.
