L92's on a turbo car?
cam wise...its a traditional split 238/246 on a 117lsa. here's an idle vid:
http://www.youtube.com/watch?v=g8gRCx8_fs0
Damn these heads seem to just work when turbocharged regardless of reverse or traditonal split.
Wierd
The real reason I had these heads ported was that I was a bit disappointed with how they came out of the box. I got 2 sets, a year apart,and they were all the same. All full of slag and imperfections, and all the machined surfaces were way rough, including the decks. The WCCH treatment made them a lot nicer. I don't see how they could have sealed with how rough the decks were, but maybe???
. I bet both of those cars are useless in first gear on the street.
But the as cast ports should at least be even and not full of casting flash. If GM concentrates on making a top quality mold, the as cast ports will be fairly smooth and consistant.
I have used several different online calculators for CR. Static comes out to 9.5-9.8 depending on which one you use.
Original thread is here... some things have changed from then....
https://ls1tech.com/forums/forced-in...tml?highlight=
First startup...
Dyno results here.....
Bang for the buck, they are great heads though! Maybe when we start really shoving air in them we'll have issues with the "thin deck" but so far I can't say that its been a problem, and we've had over 20psi on them so far.
i've read some conflicting info so need clarification. do the assembled heads have additional work done to them versus the bare heads, e.g. decked, flashing cleaned better?
Unless you opt for the GMPP CNC versions (or aftermarket) they will all be the same.
I'm with Frank in the fack that at 20psi it won't make a sh*t of difference how smooth the ports are.
There is some value in a quick clean up to the deck surface to ensure a good seal.
i guess the l92/ls3 deck thickness "flaw" is just a myth.
many are chiming in with 700+rwhp on stock l92 heads
cool.
