Prochgr Enclosed or Open---Bypass vlv pro and cons
http://www.procharger.com/store/inde...d&productId=20
to a race valve. Looking for a bit of insight on the pros and cons when it comes to either the Open or Closed version.
http://www.procharger.com/store/inde...od&productId=9
http://www.procharger.com/store/inde...od&productId=8
I am not into the loud rush of air when it opens, even though I dont think you would hear it over the F1a. I dont have a problem with the return plumbing be it I am not using the stock air inlet hat.
http://i3.photobucket.com/albums/y65...install071.jpg
http://i3.photobucket.com/albums/y65...install078.jpg
Even had another thought of adding another Proflow off of my RH side intercooler (still running the twins) to the inlet hat.
Current plumbing worked fine with the D1 up to 640hp. Im sure the F1a could use a bit more help. Setup the F1a for around 15psi.
http://videos.streetfire.net/video/F...awk_206484.htm
watch 1:45-2:00 gives you a good idea.
http://www.exoticperformanceplus.com...html?item=1261
Check out my price on the ProCharger race valve. Bob
