To anyone building a downpipe for their Borg
Thanks
Rob@modularturbo
4" pipe 6" radius
3" pipe in 4" or 6" radius
For example an MT DP kit for a T6 5" outlet would be something like this:
5" stub pipe with v band ring welded in mild steel
5" clamp SS
5" to 4" reducer pipe in mild steel
2X 4" 45 degree bends in mild steel
1X 4" 90 degree bends in mild steel
TOTAL on this example would be = 199.00 shipped
I know that its not the cheapest, but I think that you would be happy to know that if you need to exchange a piece because you measured wrong or have any other issues you can return the piece for the right one as many times as you need to within reason of course. Also I will work with you to make sure you get the right parts. I believe that should justify the cost.
Thanks
Rob
4" pipe 6" radius
5" clamp SS
Thanks
Rob
Jon
