magnacharger
are you planning to turn up the boost later on ? (everybody does, it's addictive)
if you are planning on going with more boost later on go with a lower cr. i personally would go with 8.5:1 so i can run more psi on pump gas. also meth will hep you out too.
The 112 is going to limit the 408. It just depends on what your power goals are. You could build a 346 and use the 112 blower and have a crazy amount of tourqe.
Check out the thread that MTI has right now about their new magnacharger kit.
