T-bolt Q.
Old Jan 13, 2009 | 06:48 PM
hawk584's Avatar
Default T-bolt Q.
what size T-bolt clamp for an lt1 Tb?
Old Jan 13, 2009 | 07:44 PM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
have you tried measuring it w/ a flat tape?
Old Jan 13, 2009 | 09:08 PM
koolaid_kid's Avatar
Measure the circumference. (I used a string and a ruler.) Divide by pi (3.1415 will suffice). This will give you the diameter of the clamp you will need. (Should be 4). Keep in mind, if you are planning on putting something on the tb, like a hose or piece of silicone, you should take that into account when you measure for and order the clamp, because the diameter will be slightly larger.
