5.3L Turbo Build
I have a Lunati hydraulic roller tappet cam.
Specs:
Advertised Duration (Int/Exh): 282/287
Duration @ .050 (Int/Exh): 218/221
Gross Valve Lift (Int/Exh): .526/.534
LSA/ICL: 116/112
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2000-5000
Would this be a cam that could be used for such an application?
I'm just trying to get as much info as possible to make sure i'm headed on the right track.
Any information and suggestions would be highly appreciated.
http://www.theturboforums.com/smf/in...topic=117581.0
I see much searching in your future.
