38mm wastegate to small for 80mm
I could run around the internet and tell people that a 38mm gate would work on my PT88.....
but would those people who saw, and copied my setup, realize that I had a STOCK catback muffler? And that when I failed to mention that when I opened the 3" cutout in the mid pipe I picked up 4 psi, and that when I opened the 4" cutout on the down pipe itself, I picked up another 4 psi? Gee, now all of a sudden Im running 12 psi..... where did all of that boost come from? I didnt change turbos!!??
I run the BIGGEST gate I can physically fit. The days of blowing open gates really are not an issue with todays boost controllers and gate designs, but its up to YOU to figure out what YOU need. Sure, If your setup is poorly matched, you might have a severe back pressure issue, but that is where it goes beyond just bolting on parts.
I like to control boost
So I run a big gate. If you need more boost, add a bigger spring
Its much easier to swap springs, than swap gates.My point is, your setup is an anamoly. I would never use a 38mm gate to try and control a 76mm turbo
Its much easier to swap springs, than swap gates.ohshixgoat - pm returned.
, don't listen to me. I'm just a dumb truck guy who doesn't know anything about turbos... I'll go back to my corner now and keep working on my own projects that probable won't work either... Have you checked to make sure your blow off valve is not opening or leaking?
then tried a double spring and without any changes to my boost controller,set-up, or tune I could make 6-7 on gate.
not sure if its the fix your looking for, but I had a mp76 q trim with a .96 ar 2.5" up pipes in a homemade set-up. the velocity my set-up was making was enough to push the wastegate open and limit boost..
What controller do you have? I would play with some different WG springs for sure. My Turbosmart WG is pretty accurate spring wise. I have done some testing using regulated air pressure from an air hose in my shop.
If I have 15 psi worth of springs in there it takes 15 psi from the air hose to open it. Now that doesn't take into effect any pressure coming from back pressure in the exhaust pushing at the same time.
I sure hope you get this thing up to potential soon as I am waiting to see the results of this comp turbo. I was thinking of getting one for my next build.
my buddy had a tattoo on his forehead after taking the last bolt out of the top..
I don't know if 875whp is possible but that would be awesome. Its going to be around 18psi on 110 octane. Last years was on pump 93
