heads for turbo ls1????
Old Jan 24, 2009 | 12:43 PM
monte70camaro's Avatar
Exclamation heads for turbo ls1????
been told the 317 72cc truck heads to help with compression. can someone give me a compearison of these heads to the afr225's or the patriot227's...is it worth the extra coast of the after market stuff?
Old Jan 24, 2009 | 02:01 PM
TurboAv's Avatar
The aftermarket heads that are completely new castings have a thicker deck that will handle more boost without walking around on the block, like AFR, ETP, Dart, etc. How much boost you planning on running?
Old Jan 24, 2009 | 03:36 PM
Default boost!!!!
some where between 14 & 20pds !!!!! depending on traction!!!!
Old Jan 25, 2009 | 12:17 PM
Default heads
how about the dart 250cc has anyone run these!!!!!
Chevy LS1 PRO1 CNC Heads
it's between these and the afr 225cc!!!!!
