? about waste gate
Old Oct 7, 2003 | 08:36 AM
Assassin's Avatar
Default ? about waste gate
does it go on the exhaust side before the turbo or on the compressed intake side?, gimme some explination, thanks
Old Oct 7, 2003 | 09:11 AM
y2khawk's Avatar
Default Re: ? about waste gate
wastegate is on the exhaust side before the turbo. Diverts exhaust away from the turbine. Less flow to the turbine results in a slower spinning turbine and thus slower spinning compressor wheel. Slower = less boost.
Old Oct 7, 2003 | 09:38 AM
Assassin's Avatar
is there an adjustable waste gate or do you just have to keep replacing the springs?, or does the boost controller go between the vaccume line from the compressed air side to the waste gate?
Old Oct 7, 2003 | 09:54 AM
y2khawk's Avatar
you can do both.
There are semi-adjustable wastegates, basically you pre-load the spring a bit to change the boost level.
you run into issues if you try to turn a low pressure spring up too much with preload. You get to a point were there's so much preload in the spring that it's basically at coil bind and it can't open any more. You end up with boost creep then.
It's better to use a light spring and use a controller to get the level you want. Overall response and controlibilty are pretty specific to your setup however.
Old Oct 7, 2003 | 10:13 AM
Assassin's Avatar
is that where the boost controller goes, between the waste gate line and the compressed air side on the turbo?
Old Oct 7, 2003 | 10:56 AM
smokinHawk's Avatar
yes
Old Oct 7, 2003 | 11:16 AM
Assassin's Avatar
thanks guys
