PT88 ok to add oil restrictor?
I noticed immediately after the install of the PT88 that my oil pressure dropped significantly at idle and cruise, the PT78HPS seemed to have a built in restrictor on the center section and oil pressure was fine. is it ok to add a restrictor to the oil supply line and if so what size. currently I have a -4an feed line to a normal -4an/npt screw in fitting on the turbo. the cavity on the PT88 is significantly larger and I am pretty sure since nothing else has changed that this is the cause for the pressure drop.
for a restrictor do you just drill a nitrous fitting to the appropriate opening size and insert between the female hose fitting and male screw in fitting?
Thanks in advance!
Chris
any other thoughts?
Chris
maybe pump or bearings?
, well hopefully not the case (knock on wood) but im sure the problem lies somewhere else. Check every possible source it might be something semi easy to fix. Good luck
back to the drawing board.. I think I am going to give one of the budget Garrett Units a try the GT88. or possibly go twins. have to think this one through some.
Chris
Thanks.. I am looking at either going to the GT88 or maybe some twins.... not sure yet, I have already sold the single setup with a PT78mm turbo on it and was talking to Jose about the GT88 as soon as I sold this one so.. that is where I am..
from all the larger turbos out there I am windering if a set of smaller units may be more reliable, seems like most shaft breakages and issues are from the 88+mm turbos.. what are your thoughts being that you probably see alot of rebuilds and such come through?
Thanks!
Chris
Thanks!
Chris
I guess I am just a little gun shy now with a torn up 3 week old 1600.00 turbo in my shop...
