Fitch fuel system
Old Feb 12, 2009 | 03:06 PM
maxgee's Avatar
Default Fitch fuel system
Saw it on a Horsepower show, seen it in magazines and appears to be a proven product. I was thinking of going E85 permanently but I would need bigger injectors around $300 but this is $195 and I can use regularily available gas. http://www.fitchfuelcatalyst.com/products/reviews.cfm
Give me your input and specially if you have used this product.
Old Feb 12, 2009 | 03:42 PM
themachasy's Avatar
I don't see how this would increase anything, seems like an overglorified fuel filter. E85 is used 20-30% more quickly anyway so you might not see much of a gain in economy, but its around 105 octane so you could add a **** ton of timing to your car.
Old Feb 12, 2009 | 03:45 PM
hotrod04's Avatar
I installed this unit on my 06 cad escalade and went from 18.4mpg to 19.7mpg. Hwy It works.
Old Feb 12, 2009 | 03:58 PM
lifeisgood's Avatar
yes it works and with the timing advantage its good stuff..but it burns a **** ton faster
Old Feb 12, 2009 | 08:27 PM
maxgee's Avatar
i've used e85 and added a couple degrees timing.
this fitch is something permanent and from what i've read, i can add timing with this also and gain mpg.
