could u put a kenne bell on a lt1 conversion
Old Feb 14, 2009 | 09:38 PM
badazzt/a's Avatar
Default could u put a kenne bell on a lt1 conversion
bought a 97 z28 it has a ls1 conversion and it looks like there is alot of room under there possibly for a kenne bell i will try and get some pics up so i could get better insight.
Old Feb 14, 2009 | 09:50 PM
Wesmanw02's Avatar
I don't see how there would be any more room under the cowl than a 98-02 car has, its basically the same body. Unless maybe some kind of k-member drop was done??
Old Feb 14, 2009 | 10:17 PM
badazzt/a's Avatar
yea it has a tubular k member and all other aftermarket suspension work.
Old Feb 14, 2009 | 10:21 PM
MrElectric03's Avatar
There is a kit floating around to fit a magnacharger under the cowl but a kennie bell is a bit larger a think. That kit uses spacers between the k member and the body.
Old Feb 14, 2009 | 10:25 PM
Sharpe's Avatar
^Like he said.
But, if you're that into it, cut the cowl and windshield and put a Sunco hood on it.
