Do I need to change MAP sensor ?
Old Feb 27, 2009 | 04:46 AM
kevtherev's Avatar
Default Do I need to change MAP sensor ?
Just fitted P1SC onto basically stock 2002 LS1 so expecting around 7lb boost.Question is will stock MAP sensor do it's job ?
Old Feb 27, 2009 | 06:31 AM
ls1290's Avatar
Dumb Ass Vette Moderator
If you still have and are using the MAF in the car, you do not need to touch the stock MAP sensor. If you do a Speed Density tune, then you will need to remove the stock MAF and install a 2-bar MAP sensor.
Old Feb 27, 2009 | 07:06 PM
s10mods's Avatar
do the stock SC 3800's come with a 2 bar map sensor?
