procharged thirdgen
Old Mar 5, 2009 | 04:21 PM
irocbmx's Avatar
So I just put my order in with Bob at E.P.P. for a procharger universal LSX serpentine kit with a D1SC. We'll see how everything goes.
Old Mar 5, 2009 | 05:48 PM
EPP's Avatar
EPP
Thumbs up
Thanks for the order, I appreciate it! Bob
Old Mar 6, 2009 | 01:20 PM
VigilanteRed's Avatar
Check out www.thirdgen.org. they will have more information on thirdgen's than you will ever need. I'm a member with my 84 2z8. They are really good about getting back fast.
Old Mar 6, 2009 | 05:49 PM
kikass_z28's Avatar
I have posted in two different sections with almost zero feedback.
Old Mar 6, 2009 | 05:51 PM
kikass_z28's Avatar
That is awesome. Keep us updated and take lots of pics if you can.
Old Mar 6, 2009 | 07:13 PM
irocbmx's Avatar
yeah, I'll make sure i post up plenty of pics. I have been a member of thirdgen.org for about six years, as far as I know there is nobody that has done a centrfugal in a lsx thirdgen. All that I have seen are a few positive displacement blowers and a few turbos.
Old Mar 15, 2009 | 10:04 PM
kikass_z28's Avatar
Any updates?
Old Apr 8, 2009 | 12:19 PM
EPP's Avatar
EPP
Here is this new combination in a 3rd gen.
irocbmx, I couldn't get your e-mail to work. Bob
Old Apr 3, 2010 | 09:56 AM
timmyboy's Avatar
Did you (or anybody) using this kit with that surpentine setup have clearance issuses with the power steering pump clearing the stock steering box? It looks really close? Thanks Tim
Old Apr 20, 2010 | 07:14 PM
92CamaroZ03's Avatar
any updates
Old Apr 29, 2010 | 02:52 PM
NemeSS's Avatar
Default 8 rib p600b 3rd gen / sbc - ls swap
im working on building a 6rib drive p600b based for blow thru swap applications. designed around 3rd gens but will/should work anywhere sbc's use to live. use sbc alt, type II GM PS pump, equipped with 8rib pulleys
8rib drive crank pulley to run all accesories off single belt.
also allow bypass of blower with shorter belt. chose p600b. because it cheeper and slightly more compact. than other ati blowers. supposed to support 775bhp
currently in rough cut brackets phase.
deciding on whether to use .75 aluminum bracket or .5 steel bracket.
soon as i can get all sorted out. will start thread with pix
Old May 3, 2010 | 02:22 PM
  #32
Thomas Aquinas's Avatar
I don't have an LSX engine in my thirdgen, but my procharger sits in about the same spot as the one in the picture Bob posted. I'm using a standard SBC bracket for it and I have the Type 2 power steering pump.
In either case, getting a good inlet setup for the procharger is a real hassle with the stock brake master cylinder. I wish I would have went with a 98-02 f-body one when I was doing my brakes.
Hope some of that helped.
Old May 4, 2010 | 07:46 AM
  #33
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thumbs up
Good information, thanks! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jun 17, 2010 | 07:32 PM
  #34
zracer92's Avatar
Any updates on this??
