LS turbo on the cheap?
STOCK 5.3 160k miles at time of swap $250
Car intake/ Zo6 cam-springs
NO engine mods, NO bolts, NO different heads
S475 BW turbo in my case, Master Power T70 would be a GREAT budget choice
I pushed mine to 10lbs at first and ran 132 mph in a 3140# car. The ET sucked at 10.9 but that was with a 2.1 60' since the back of the car is all stock, little 235 tires, OPEN rear, mono leafs...NO traction device whatsoever.
I then went up to 14-15lbs of boost...still same setup, still on pump gas...made the 10lbs feel like nothing, whole different beast at 14-15lbs. Im sure it would trap 135-136 like that. In a car that worked even just a little bit (like 1.75 60') that would equate to LOW ten second passes...
My same combo on 12lbs boost would last a long time for little dollars and in a halfass working car would make easy high ten second passes at best. Worst case scenario you break a piston and replace the cheap engine. It took 18lbs on pump gas to hurt my all stock one....NO meth
Have fun!
http://www.neweraperformanceparts.com/
truck $3500
5.3 Engine with all accessories $800
LS6 cam and springs
Turbo $600
304 Stainless pipes, bends for custom turbo kit and misc flanges $600
MegaSquirt $500
wideband $300
MSD box $300
Meth injection $300
TH400 with Tbrake $700
Fuel system (dual pumps, 72 lb injectors, rails, regulator) $800
FMIC $200
Gauges $200
Driveshaft $250
Drag radials and cheapo Rims $500
Posi rear axle and girdled cover $400
just to give you an idea. That doesnt include my nitrous kit, BOV or wastegate that I already had from another project. Plus dont forget about all the nickel and dime stuff that adds up WAYYYY to fast
I added the cost to build my entire drivetrane in my Nova...5.3L, cam, valve springs, intake, injectors, turbo and all parts for it, intercooler, HP Tuners, Wideband, rebuild my TH350, Fuel system, Coan rebuilt my converter, Pretty much everything except the rear end. around $5k. 3 years later still runs good, and there isnt a time I drive it that it isnt to the floor. Daily driven everywhere in the summer.
Go with 60s off the bat is my advice don't bother with 42s. If you want past 600rwhp then likley should go to dual intank setup like you can see on lonnies,nastys sites to name a couple. Or big single if you want to go past 1000rwhp Much past 600rwhp would also do bigger lines, rails and of course a boost referenced regulator.
I am going to twin intank with bigger lines ,rails and boost ref reg and also going to be upgrading to 79 pounders think right away. Might even have to go bigger later on will have to see.
Twin pumps-$200
Regulator-$160
20ft -8 $100
20ft -6$100
10 Micron filter $60
5 Micron filter $50
And that is not counting your fuel rails, cross over, fittings, or modified pump harness.
