turbo cam
i will give some specs on build and anyone jump in and tell me if cam will do fine.
377ci ls3
afr 225
9.5:1 comp
ported ls2 intake(for now)
APS turbo kit. mit20 around 50lb min
manual
purpose mostly street race and track fun. and dyno star.
I've seen over 600rwhp with a stock ls1 cam,over 700rwhp with an ls6 cam,we made over 1000rwhp in Kyle's car with a 370 and a 228 cam,Fireball went 8.30's with a mid 240's cam in a 6.0.I made over 2500hp and went over 200mph in the 1/4 with a mid 250's cam in a 436 sbc.
last thing i have is that every combo requires a different cam,there is no one cam fits all combinations.
When you have the right parts selection IMO, you make the same power at less boost level, and have good power under the curve.
Now granted I don't entirely dislike reverse split cams however, I think alot of people tend overuse them, or use them on builds that have 2:1 backpressure or less.
I'm pretty sure that both of the cars that made north of 1200 RWHP at the LSX shootout last year had LS2s with reverse splits...actually...I pretty sure both had the same exact camshaft. I'm positive about one of them since it was my turd...
I tend to agree, most anything will work. Wolfe runs some REAL jacked up cams. They obviously work though.
I think for picking cams you need to consider the following:
-Sound... Lope or no lope
-Driveability... Near stock or can tolerate some cam surge etc
-Peak RPM... Where will the combo be shifted
-Power goal... 500, 600, 700, 800... at the crank?
-Single or twins...
-Single or twins...
-Driveability... Near stock or can tolerate some cam surge etc near stock
-Peak RPM... Where will the combo be shifted 6500 ish
-Power goal... 500, 600, 700, 800... at the crank? 650-750 at street and 1000 wheel at track
-Single or twins... twins
this help
That epp cam sounds fine too. Bit of lope I think.Truth is just about any cams works not too bad since you are fi anyway.I mostly wanted a nice smooth idle with no surge that too many of my friends with wild cams have. and you can't really tune that surge out. One guy is pro tuner and his vette is horrible for cam surge. I hate it but whatever flloats your boat. Overcamming is one of the biggest mistakes. My car is so streetable its just ridiculous.When put in the auto bet my grandma if she were still alive could drive in heavy traffic.
Some guys like to go hardcore. Again if thats what you want.
and here is my thinking. if you add 14.7 psi to an engine, lets say you theoretically double the output.
so, if the engine is making 400hp at 5500 rpms NA, then it would make 800hp at 5500rpms at 14.7 psi boost.
so if you install a cam that makes only 380hp at 5500rpms NA, then the turbo engine will make 760hp at 5500rpms at 14.7psi of boost.
so, in my mind, the turbo follows the NA curve and a good NA cam will also be a good turbo cam.
someone fill in the gaps for me.
