turbo cam
When calculating restriction orifice flow, the increase in flow is proportional to the square root of the ratio of the dP's. In other words, when doubling upstream pressure, flow only increases by 41%.
When calculating engine hp from boost, the increase in power is proportional to the ratio of presures. In other words, when doubling upstream pressure (e.g. from NA to 14.7 psi boost), power increases by 100%. This is [yet another] way to explain why an engine should not be viewed as a restriction.
If you google search 348 99 turbo camaro ss gm high tech, you will find a 638 hp on 91 pump gas and 850 hp on c16 ls1 using a cam with a 113lsa. This information tells me that depending on what I am looking for out of my car, running a n/a cam may not be a bad idea.
With that said, I no longer feel obligated to buy a turbo cam.
Hope this helps.
Hope this helps.
Installing better heads IS removal of a restriction! The port/valve is a hole that restricts flow. The cylinder that it leads to IS NOT a restriction.
Cant you just tell me what cam to buy? God damn it, Im a doer not a thinker.
A 350 CI engine at 6000 with 100% VE moves approximately 607 CFM. I dont care if you have 40 psi of atmosphere, the motor will not move air any faster. So if the turbo is ingesting 900 CFM of air, and the motor is only moving 607 CFM, how is the motor not a restriction? If it wasn't a restriction, the motor would move 900 cfm of air, and the boost gauge would read 0.
I think you guys are looking at the motor in 2 different ways. As in mikes hose with a nozzle example, you are treating the engine as the "nozzle" which everyone agreed is a restriction and seeing the turbo system as the "hose." mike isnt viewing it the same and is actually looking more in depth into the motor and in way explaining how to improve flow through the "nozzle" aka the motor.
Just my opinion as an outsider because i believe everyone is saying the same thing different just in different ways.
It makes it seem like an arbitrary number that is only there because of some fault or deficiency.
At WOT, how is positive and negative manifold pressure -both- defined as a measure of restriction?
I'm sticking with- Boost is a value of atmosphere available for the engine to consume.
if boost were a measure of restriction, wouldnt exhaust reversion from a high overlap cam be the ultimate restriction? ie, the backpressure is greater than the boost pressure, so effectively, its pushing back the boost.
why wouldnt this create insane boost levels? since boost is supposedly a measure of restriction ?
Eventually BP get's high enough that you run out of time for the intake air to flow into the cylinder or most all the exhaust to leave the cyl.
Either way power goes flat or down.
boost as a restriction is relative. 25 psi on a 165cc port is a world different from 25 psi on an LS7 port... both on the same CID.
The difference is in cylinder air density.
Do some digging on the guys running TC7x turbos and T7x S trims. Big diff in power. Some is the comp housing. But a big factor is the 12mm bigger turbine wheel causing less BP and more HP for same boost #.
AFA cam timing... I think overlap in itself isn't what's making the power. -I've yet to finish this whole thread yet if I'm repeating-
It's the actual open/close points vs boost/CR/BP that's making the power.
I've read several posts by cam designers saying they don't know what the LSA is until they are done and then calculate it. Meaning they don't even consider it. I had to ask what the lsa was on a custom I got spec'd and he had to calc it right then on the phone. JMOP, but I think most guys over cam their turbo setups because they don't consider BP and the RPM range of the LR intake. 23x @ .050 on a 68mm turbine is an example. Shawn said the same on the first or second page.
But the IC artificially raises the exh bp by requiring more turbine power to get boost past the IC restriction.
For the DP and exhaust, it's starting to look to me like you divide your boosted HP by 2 and size your exhaust for that HP to be close.
guy with a 114 on a bbc claims 25psi backpressure at 25psi boost and gives some logical reasons why his bp is so low
http://www.yellowbullet.com/forum/sh...t=backpressure
