Highest Boost a LS6 Manifold Can Handle??
Old Mar 15, 2009 | 10:26 PM
barnat's Avatar
Default weiland street warrior?
Ive also heard the new Weiland street warrior was built stronger then the LS6
I remember reading about it when they showed it at Sema last year.and supposedly flows better then the LS6 by 32hp and 31ft lbs of torque. i was actually thinking of buying one and insatalling before my tune
Old Mar 15, 2009 | 11:00 PM
93formto98T/A's Avatar
Even if this was the case on an N/A motor-which I would have to see real world testing to believe anyhow, it would NOT be the case in an FI app as the air is being compressed into the motor and flow characteristics of an intake aren't going to come into play unless you're talking well over 1000hp. Frankly, it would be a waste of $$ on a HP gain standpoint. I'm running a ported LS7 intake shooting for 1300rwhp to give you an example.
Old Mar 15, 2009 | 11:35 PM
Gordon0652's Avatar
Originally Posted by Moparnos (The SLP Guy)
lol your crazy
i'll be doing that today! Hoping for a
Old Mar 15, 2009 | 11:56 PM
bigsticksupra's Avatar
how much is the FAST good for? are there any power gains using the FAST instead of the LS6 with boost?
Old Mar 16, 2009 | 04:20 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Originally Posted by kp
I wouldnt stand anywhere near that thing, it could go off like a grenade if you try that..
The back will pop off first, so just stand in front of it Oh, and don't forget to get a video of it too!
Old Mar 16, 2009 | 09:24 AM
Gordon0652's Avatar
I need a quick idea of how i should plug up the intake ports. Then i will be good and i will video it.
Old Mar 16, 2009 | 09:53 AM
Inspector12's Avatar
TT-TECH Veteran
Bolt them to an old set of heads or make a plate of metal on it and the TB location with your air fittings etc... Like a leak down tester so you can test different presures and increase it slowly etc... I wouldn't stand any where close when you get above the 18lbs etc...
Old Mar 16, 2009 | 01:27 PM
stevieturbo's Avatar
But it would be cool !!!
Get some Mythbusters ballistic shields lol
Old Mar 16, 2009 | 01:41 PM
dschmittie1's Avatar
Bolt the intake to some boards or something with the seals still on the intake that should work
Old Mar 16, 2009 | 01:45 PM
Thick sheet of perspex bolted to it.....
Solid wood might do, not sure how airtight it would be though. If the compressor supplies enough air, it might be ok.
Or a bit harder, a chunk of steel, or Alu.
Or finally, if you have a pair of heads sitting about...bolt it up. Would be interesting to see when the intake valves open too under pressure ( dont forget to plug the rocker bolt holes if the heads are ported and have broken through )
Old Mar 16, 2009 | 01:58 PM
oddwraith's Avatar
How you going to get a good seal to pump the air in through? Still, I wouldn't stand near it
Old Mar 16, 2009 | 02:17 PM
  #32
getting air in is easy.
There are various smaller fittings you could use, after blocking up the TB hole too of course.
Old Mar 20, 2009 | 05:40 PM
  #33
ChevyChad's Avatar
this guy has the right idea.. i would use something a little more sturdy than duct tape tho for the TB opening
(got this from Chris10an's profile)
Old Mar 21, 2009 | 11:12 PM
  #34
NateLS1's Avatar
Interesting question.
Just for kicks i just removed my LS1 intake so i will use that for an experiment. I will plug all the holes and fill it up with air until it pops. Could be fun.
FWIW, I once sealed a tire valve stem in a small Poland Spring bottle and filled it just over 90 PSI before it blew. And that plastic is much much thinner than an intake manifold.
I did this as a prank to scare the sht out of a co worker
Old Jul 4, 2009 | 10:05 PM
  #35
camarokid94's Avatar
i hope your ok as we have yet to see the results lets hope nothing happened lol
