need some advice for a turbo setup
Old Mar 13, 2009 | 08:19 AM
importkiller_SS's Avatar
Default need some advice for a turbo setup
I want to go to a turbo setup i will be fabin with truck manifolds... but im just wondering how well the current setup will adapt to a turbo setup
i have a set of LS6 heads with Patriot xtreme springs, a cam i think might be too much for a turbo setup which is a 233/239 .598/.603" wth a 113LSA
other than that i have a stock bottom end with 90K miles on it
wat would you suggest i do?
Old Mar 13, 2009 | 08:28 AM
98Z28CobraKiller's Avatar
Restricted User
The only thing that I would worry about initially is the compression. You may not get away with very much timing on pump gas.
