? QUESTION ABOUT VENTING WASTGATE TO ATMOSPHERE.
Old Oct 20, 2003 | 06:38 PM
MYTURBOT/A's Avatar
Default ? QUESTION ABOUT VENTING WASTGATE TO ATMOSPHERE.
I had to pull my crossover off my car to fix a few small exhaust leaks. Well I thought i`d try venting the wastgate to atmosphere so I made a block off plate for the exhaust pipe and repositioned the wastgate so its blowing the exhaust at the ground. well my butt dyno says it pulls a little harder up top but not much. other then being really loud is there any pros or cons to doing this don`t want to mess anything up.
Old Oct 20, 2003 | 08:46 PM
qqwqeqwrqwqtq's Avatar
Default Re: ? QUESTION ABOUT VENTING WASTGATE TO ATMOSPHERE.
You can make more power by venting the gate to atmosphere. (because the exhaust doesn't have to flow it anymore).
But IMO, it doesn't sound very good.
Old Oct 21, 2003 | 12:28 AM
MYTURBOT/A's Avatar
No it don`t sound the best but it`s not any worse than the bassani catback that sounds like a fart can on steroids thats why i run with the cutout open.
Old Oct 21, 2003 | 06:04 AM
smokinHawk's Avatar
yes you will make some gains as it is more free exhaust when you reach full boost.
no bad things, cept the sound and not emmission leagal, if you have emmission laws
Old Oct 21, 2003 | 11:05 AM
MYTURBOT/A's Avatar
Well i don`t have to pass any emissions test so I should be alright. Since it won`t hurt anything I`ll leave it like it is until I get tired of the noise. Thanks guys.
Old Oct 22, 2003 | 02:12 AM
MYTURBOT/A's Avatar
Well the final results are in took the car out today with a-tap. I made four, 3rd gear runs up to redline. previously I could not get past 385gm/sec on the MAF. today All four runs were above 425gm/sec with the third run being the highest at 442gm/sec. So i guess that moving the wastegate was a good idea, If i can handle the noise.
