Boost Guys Opinion
Old Mar 23, 2009 | 01:42 PM
1320's Avatar
He already ran it na....bypassing the pipes. Same problem, na in speed density.
It also has the same pipes as Zombies car and a few others along with the intercooler.
Old Mar 23, 2009 | 02:12 PM
BuffJoeyD's Avatar
I hate to say it, but it was asked if you check the plugs after any of your pulls- Just because you have the fuel system, doesnt mean its working- Ive tuned cars and had them at perfect AFR- but could tell they werent running right- simple plug pull told the story. - Still think its fuel or cam
Old Mar 23, 2009 | 03:41 PM
Kaneman's Avatar
We pulled the turbo off and it still does it. Just for the heck of it I am going to swap the PCM since that is pretty easy but like others I am leaning towards the cam being a tooth off or even just replacing the cam.
Kane
Originally Posted by longrange4u
Have you measured your backpressure? I am just throwing ideas out... Big engine.. smaller turbo. Could 5krpm be where you are exceeding your backpressure limit? Whats your hot and cold side piping? I see that you thought of this and went to a .96... but maybe the limit is your pipes not your turbo?
