Turn up the boost or upgrade the turbo ?
I'll have to collect a bunch of datalogs and see what the relation to oil temp vs ambient temp vs intake air temp vs boost vs boost duration. Heh, thats a lot of stuff to compare, but you get the idea. I think the duration (of the boost) is my IAT heater.. makes sense. Like an overdriven M112 Eaton...
What fluctuations in IAT do you see @ a given boost level.
I am not saying he should be shooting to make crazy HP... but when you go F/I (that investment) you should get at LEAST 30-40+% increase in HP... LS2 is ~420HP + 35% = 567HP.
His other option (Again in my opinion) is to keep doing what he is doing... miss a meth spray and blow up his motor... all for less then 500RWHP??? Upgrade the turbo, get an FMIC... run safe boost WITHIN the efficency range of a turbo and get good safe results.
The FMIC I have on my car is Amazing (LMR Josh is a beast)... We saw 16lbs of boost runs with the IAT's at 107deg. When spending FI money... its worth it for the safety.
Also this is kind of the same question, but if I already have a big enough turbo for my car, is it safer to turn the boost up a little more or install a turbo cam?
