boost creep or no?
the old turbo was basically a t67 with a .81 exhuast housing. the new one is a tc78 with a bigger exhaust wheel and a .96 housing. the wastegate is a 38mm on the crossover pipe.
You might be able to band aid it by installing a larger gate, or by having a small turbine housing/wheel to back it up and force it out the gate.
Also every setup I have ever built, truck or car has both banks feeding the gate. Any other way is not correct. If it does work its because of other problems in the system (high back pressure).
hellbents10, how do you gate both sides? do you put the turbo in the middle? just trying to think of a way to do it with the gate down there.
