So Close, But So Far.....
Old Oct 24, 2003 | 01:03 PM
BIGBOS's Avatar
Default So Close, But So Far.....
Car hit the dyno this morning.......I have a 40.8" belt on it, either NAPA or Carquest 8 rib, the carquest is on there with an ASP blower pulley (3.3")...
The problem we had is that the belt is now slipping BAD, and we had enough tension on it to break the pins on the crank pulley....so now they are going to drill and tap it and put it back on...
Now..
Whats the next belt size down from 40.8" thats an 8 rib...
Also we are going to try the 3.3" Reichard racing pulley that I have...
On a good note......
The brackets don't flex
The belts don't walk
The steel idler is doing fine
The tensioner is maxed out and the belt still slips....maybe the reichard will pull through?
WILL THERE EVER BE A GOOD DAY W/MY CAR
Old Oct 24, 2003 | 02:33 PM
BIGBOS's Avatar
UPDATE:
Went out and bought a 39" Dayco 8 rib belt, going to combine this with the "ultra grip" Reichard Racing 3.3" blower pulley...
Car is probably going back on the dyno early next week....
Maybe having the belt 1" shorted combined with the pulley should stop the slipping....
Old Oct 24, 2003 | 02:35 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
At least the belt didn't walk off right?
Old Oct 24, 2003 | 02:38 PM
Camaro_Zach's Avatar
making progress at least right? I hope this fixes it for ya. Keep us informed! good luck!
Old Oct 25, 2003 | 12:17 PM
Holes02's Avatar
Bos. That RR "ultra-grip" pulley should help out alot. There are a lot of Mustang guys using them with serpentine systems that swear by them. Looks like finally you can see the light at the end of the tunnel. Lets hope this all gets sorted out so you can get the car out for at least a little while before snowfall....
Old Oct 25, 2003 | 07:36 PM
BIGBOS's Avatar
I hope so, keep your fingers crossed...
