Car wont start, need your help
Old May 12, 2009 | 09:01 AM
ddnspider's Avatar
EE101....if you're supplying a ground path then are you still not completing the path?Whats the difference between supplying a power signal or a ground signal?Nothing. You're still completing the circuit and overdriving the transistors in the ECU that control the injectors with too much current,ie a fried ECU.
Old May 12, 2009 | 09:15 AM
WS6HUMMER's Avatar
Ok, thanks for the explination.
Old May 12, 2009 | 09:28 AM
dreamls1's Avatar
nope computer is all good.
Old May 12, 2009 | 09:36 AM
ddnspider's Avatar
wow, contrats.you got off lucky. I knew someone local who fried one.
Old May 12, 2009 | 09:38 AM
98Camarod's Avatar
So it's running now or are you still having trouble?
Old May 12, 2009 | 09:57 AM
dreamls1's Avatar
My tuner has it up and straightline performance. Its running.
