Turbo plugs
Old Apr 8, 2009 | 06:10 PM
dreamls1's Avatar
Default Turbo plugs
I am running NGK TR6 plugs for my turbo car. Can i run the gap they come with or do they need to be adjusted?
Old Apr 8, 2009 | 06:47 PM
conan's Avatar
You should always check the gap before putting them in. I adjust my tr6's to a .035 gap, usually I have to close them
Old Apr 8, 2009 | 07:13 PM
98Camarod's Avatar
I put mine to .028, had some problems with the wider gap. The spark was getting blown out I guess.
Old Apr 8, 2009 | 07:50 PM
dreamls1's Avatar
what is a good gap to run?
Old Apr 8, 2009 | 08:51 PM
ModularTurbo's Avatar
It really depends on the setup and tuner .032 has always worked for me.
Old Apr 8, 2009 | 10:13 PM
Photochop's Avatar
The same kit that's on my car on the previous owners car used TR6s gapped at .035 with no issues at 14psi. On my car, TR6s have to be gapped at .028 or they'll blow out, even at 11psi.
Old Apr 9, 2009 | 12:10 AM
tomz28's Avatar
im running tr6s at .035 with 12psi so far so good but im going to .028 in the next set to see what happens
