Update
The 60 trim has nearly no lag and pulls harder then i expected. It is exceptional in the middle of the power band and is surprisingly a little loud even at only 7 pounds.
The car was running great but it is now throwing a MAF code that has me a little on the worried side. She is still running the stock MAF. The car is running very rich as well but i think this may be directly related to the MAF issue. Im not sure where to go from here. I had planned on putting the car on they dyno again for a little more aggressive tune but if the MAF is going should i just switch over to SD or just replace the stock unit and have the car returned.
also, my oil pressure is 40psi @ idle, and 60-80 when getting on it
I will post up dyno sheets when i can get close to a scaner but the car went 451 WHP and 508 WTQ running 7 psi off the waste gate.
Any plans to step up to a bit larger turbo? Those numbers are better then I thought they would be for 7lbs with such a small turbo, I bet the throttle response is very snappy.
