Doing my research, need your opinions
I want to do a T-76 setup and want to make 500hp, with the option of turning up the boost at the touch of a button to make 600+
Also do not want to go rear mounted set up.. I do not like them at all
Keep stock cubic inch 347 LS1
LS6 heads 2.08/1.57 Home porting (hoping for 330cfm)
3-angle valve job beehive springs
Stock crank
H-beam rods
-23cc Boost Pistons ??
Of course, all new bearings, seals, ect.
1.8 rockers?
Hardened pushrods
What lifters??
Cam?? 224/224 on a 114 .560-.580 maybe .600 after rockers/pushrods
Im running a 6spd so if yall think I can go bigger on the cam and still be way streetable, then give me your choice of cam
LS6 intake, some clean up porting done
stock ported TB?
What will I need to do to the fuel system?
Ignition system?
What about the turbo specs? What size compressor/turbine wheels?
Has anyone done their own custom headers and piping? I would like to see pictures of peoples set ups, I know piping is crucial for the system to be efficient. Ive seen people turn their boost down 3 psi and still make more power because they re-did their piping a little better... Id also like to see intercooler arrangements, oil feed lines, ect.
That is all I can think of at the moment.. I appreciate any comments.
