ati damper
Old Apr 19, 2009 | 05:38 PM
02 z/28's Avatar
Default ati damper
Hey guys I need some help,how can you tell if you have the ati damper seated all the way?If I look in the hub with the crank bolt removed the crank and key sit back about 1/4 of an inch from sitting flush where the keyway starts in the inside of the hub.Does this sound right or wrong?any help would be great thanks.
Old Apr 19, 2009 | 06:54 PM
9sectruck's Avatar
that sounds really close it should be seated
the stock crank bolts is like 211ft pounds of tourqe if u can get that on the bolt i would say it is seated
Old Apr 19, 2009 | 08:01 PM
02 z/28's Avatar
thanks,Iam just not sure if it should sit flush.I see what your saying if I can get the crank bolt to 200 plus its fine.
Old Apr 19, 2009 | 10:12 PM
Gauge's Avatar
11Second Club
If the bolt is torqued to spec and the belts line up, you're good. That's my motto, anyway.
