1000hp which block to go with
but yeah thats a sick build. back to the post though i would go iron personally but thats just me. i like the having the thought in my head that the block is stronger but theres been numerous people on here running that power level with allum. blocks. i dont think anone has asked this but do you have a budget and is this your first build?
Sean
1000 at the tires not so much
either one eventually you will get tired of the b.s. (if you drive it worth the investment) and get with something more expensive / reliable.
I chose the LQ4 block for strength and reliability. I run 900RWHP through a Turbo400 with a 4000 stall TC. I had to use a high performance water pump in order to keep the engine cool. Works well in traffic on a hot day with it.
100 passes on an aluminum block at 1000RWHP I'd say that's VERY impressive. For me...I don't like worrying about bore distortion at all! I guess I'm chicken. I removed some heavy stuff instead to counter the weight gain.
Any detonation at all and say goodbye to any motor.
Man I'm currently getting my car finished up 408/F1-A I choose the Iron block hands down. I like the fact that touching the block up in needed is no concern and at the power level your wanting your not going to notice the diff in weight. IMO go for the Iron bro best bang for your buck, if your going 1000hp plus then I would say get a high end block (lsx, warhawk etc.) I have plenty of faith in the Iron block.....GL with your choice.
