STS oil seal problem
Old Apr 27, 2009 | 09:14 PM
zapp168's Avatar
Originally Posted by 3800SII
Nice! Where can I buy a set of those! I have mine mounted to the frame, but It still makes a ton of vibration and noise...
I used the same thing, I got them from a speed shop, they come with a MSD ignition box to mount it
Old Apr 29, 2009 | 02:02 PM
3800SII's Avatar
Originally Posted by 2ktransam
They should sell something similar at any hardware store.
Thanks All! I went to Autozne yesterday. In the HELP section I found part#
49450 which are Wiper Motor Bushings.
http://www.autozone.com/autozone/cat...unting+Bushing
They come three to a pack and I needed four (bought two packs). Each pack costs $3.99. You can trim down the brass inserts a little more with a die grinder so that the don't hit your mounting surface. Works EXCELLENT!
Old May 1, 2009 | 07:04 PM
99Ws6TransAm's Avatar
just installed my shurflo pump. MUCH quieter then the STS pump. Have rubber isolaters on the pump where its mounted. i cant even hear this pump. Its definitly alot bigger then the sts junk pump.
