vortech v3 t trim
Old May 7, 2009 | 05:50 PM
YSILT1's Avatar
That was on a stock motor. They were also only spinning the blower about half what your G-Trim was spinning.
I have seen guys pick up 150hp+ with switching from the G to a T trim with only a few pound increase.
That Vette would make around 840 RWHP with a 2.62" pulley on it.
Old May 7, 2009 | 06:08 PM
99Ls1fever's Avatar
Thats Insane what is the differance between the G-Trim and the T-Trim? Bigger housings size? or Just a bigger head unit?
Old May 7, 2009 | 06:16 PM
SETc6's Avatar
Originally Posted by Chris'stransam
well i am building a 408 with L92 heads with 9.5-1 cr . I am goning to use a vortech v3 t trim . I was woundring how loud is a v3 t trim supercharger ?
its not loud at all its quite
Old May 7, 2009 | 06:32 PM
DeltaT's Avatar
The G-trim is rated at a max 600hp and the T-trim is rated at 825. Figure they are a bit conservative and you can see the difference. T-trim = Bigger air opening, air outlet, max cfm is 1200 vs 875 for the G.
Jim
Old May 7, 2009 | 07:23 PM
99Ls1fever's Avatar
Jim
Thanks, side by side is the t- trim noticeable bigger than the g trim?
Old May 7, 2009 | 09:07 PM
ss1's Avatar
ss1
Yes, the T-Trim is bigger and will not fit in the same bracket as the G-Trim. Noticably bigger? Maybe a little. You can get dimensions from Vortech's website.
Old May 12, 2009 | 10:35 AM
99Ls1fever's Avatar
What are the differances hp wise between the two blowers. if I am at 620 hp on blower with a g trim at 10 pounds. What would I be at with a t trim?
Old May 12, 2009 | 10:46 PM
YSILT1's Avatar
I have seen several guys switch to the RMCR T-Trim and pick up 100 rwhp. At the same boost level.
The T-Trim is 400 cfm larger and does not have to be spun as hard making it able to produce more power and less heat. Also the supercharger comes on way stronger at the low end.
Old May 13, 2009 | 11:14 AM
99Ls1fever's Avatar
How much is a RMCR T-Trim cost? and at the same Time I mise well find out how much the RMCR YSI costs too?
