Plastic Hat Broke
Old Nov 1, 2003 | 09:47 PM
01Bird_of_Prey's Avatar
Default Plastic Hat Broke
On my way out tonight, I heard a banging from under the car. I stopped and saw that the plastic in-take (hat) broke and hanging. I read a post about this somewhere, so I know this is common -- did a search and couldn't find anything. Does anyone know what to do? Go back with the ATI, which was purchased about a year ago or is there one better???
Got lucky this time, it didn't mess up the blades.
Old Nov 1, 2003 | 10:12 PM
nbm00ws6's Avatar
Call ATI and ask for the new design inlet hat, it's stronger/thicker.
Old Nov 3, 2003 | 07:31 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Might have been my post, I did the same thing like a month ago. And my kit is right at a year old too. I ordered the ati hat ($125!!!! ) and it has been fine since. The new one did appear to be a different material, seemed like it wasn't as brittle as the original. Thickness and shape appeared to be the same. I could see a spot where it was rubbing the fan shroud some, so I angled it away more, and I also cleaned the filter so the vacuum inside wasn't as strong. It was DIRTY . Picked up a couple psi too...
Old Nov 3, 2003 | 10:22 AM
1dirtyZ's Avatar
tell them it broke and try to get them to give you the new one chaeper.
i got mine for $75 or around that.
Old Nov 3, 2003 | 07:12 PM
Today, I called ATI and explained that I heard this is happening a lot; he said that it wasn't a common problem, but he would give it to me for half price.
Problem solved for now -- thanks for everyone's help.
Old Nov 3, 2003 | 08:07 PM
slow's Avatar
just be glad it did not mess up your unit, some have had parts sucked in, and damaged the fins.. and ati didn't care.
Ryan
Old Nov 4, 2003 | 12:15 AM
SILVER BULLET's Avatar
I had to replace mine a couple of months ago and noticed the material change. The inlet hole diameter was 1/8" larger and required a different size clamp than the stock one,
