Tensioners and Superchargers
How does the stock one fare? If you use the stock, how do you really control the belt tension if you take the time to measure it?
How does the Katech adjustable tensioner fare?
Anyone take the time to check their belt with a tensionometer like Kent Moore sells?
Thx,
Would you keep the stock tensioner and then only try the Katech if you have problems?
Stock isn't adjustable, eh? If belt tension isn't in range you are kinda screwed, right?
