Proper way to clock the turbo?
Old May 9, 2009 | 09:40 PM
SPRAYED 01's Avatar
Default Proper way to clock the turbo?
Just wondering what the official proper way to clock the turbo is?
My question is coming from a little smoking issue that i have on decel and also at really random times.
Should i just have the feed at 12 and the return at 6? Is there a better position to help with oil backing up into the turbo? I have a really tight setup with a return that isnt the best.
Also can i put a check ball in the return so it cant return back to the turbo?
Alex
Old May 9, 2009 | 11:55 PM
396375's Avatar
Clocking the feed at anywhere from 11 - 1 will work.The return line is critical.At least a number 10 line with no kinks.Have you checked end play on the shaft?
Old May 9, 2009 | 11:58 PM
12secSS's Avatar
Ideally you want the oil inlet at the 12 o'clock position and the outlet at the 6 o'clock position. You want the outlet/return line to be as big as possible and as straight as possible. Any bends or kinks will hinder the oil flow from returning to the crankcase. A check ball is not needed and can act as a restrictor to the return system. Also ensure you do not have too much oil pressure going into the center housing, as it can overwhelm the piston rings in the center housing.
Old May 10, 2009 | 08:05 AM
koolrayz's Avatar
get the check valve out. It will act as a restrictor.
