What kind of piston rings for F.I. engine?
Old Nov 2, 2003 | 01:41 PM
Whistler's Avatar
Sawzall and Welder Mod
Default What kind of piston rings for F.I. engine?
I've got Diamond dished pistons... I'm not sure if the diamond rings are woth anything or not on a turbocharged LS1.
Just looking for some input.
Old Nov 2, 2003 | 10:56 PM
Crunch's Avatar
I used the Diamond Pro-Select Rings.
I didn't really shop around for rings. I just got whatever Diamond sold with the pistons. They should be just fine.
Old Nov 3, 2003 | 05:27 AM
smokinHawk's Avatar
well after doing my engine and having as much blowby with it, instead of using what came with my JE pistons, i wish i would have used helfire rings, i plan next spring to have them redone with those.
Old Nov 3, 2003 | 06:29 PM
Silverchickn's Avatar
Smokin are you sure that Federal Mogul makes the Hellfire rings in the 3.905" bore? I looked at their site and they did not show rings of that size.
Old Nov 3, 2003 | 09:03 PM
2001WS6Vert's Avatar
I used the Diamond file to fit rings that came with the pistons. They are working very well. Good oil control, no excessive blowby, no smoke. I went .022 gap on the top 2 rings. You can get varying opinions on the ring gap.
Old Nov 4, 2003 | 05:37 AM
smokinHawk's Avatar
yes im pretty sure they will, you just need to give them your piston specs, aka build card.
also child alberts (spelling?) makes a good ring, they would be my second choice.
Old Nov 5, 2003 | 09:04 PM
phenyxTA's Avatar
Are you sure it wasn't because of the honing job or cylinders? Did you seat the rings? Not saying it wasnt the rings just some thoughts.
Old Nov 6, 2003 | 06:01 AM
smokinHawk's Avatar
maybe it was how i broke it in, how knows, thought i did it like every one told me not to softly but not real rard, varied throttle, blah, blah.
it was bored 5 over (3.905) should have been good. IDK
Old Nov 6, 2003 | 08:39 AM
ChrisB's Avatar
JE pistons normally come with hastings rings, which are pretty good rings. Really most any plasma moly normal ring set will be broken in by the time you set valve lash - before you even fire up the motor. If you are getting blowby I would guess it is either the finish put on the cylinder wall or the ring gap - do you know what it was set at?
Old Nov 6, 2003 | 01:52 PM
BIGBOS's Avatar
I used the rings that came w/the diamonds, they were $175 I believe, so far no blow by and the motor has seen 14psi....as soon as the COGS come I'm shooting for 15-16psi.....I need to get the twin 340's installed though first...
Old Nov 6, 2003 | 02:04 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I used Diamond rings, while my car has has only several hours of run time it does not smoke or use oil.
