Going TT@12psi, questions about engine build
Now, the goals for the car are going to be 10's. I would like to do it on a stock CI motor. Here's my plans, let me know if there are any problems that you guys foresee.
Stock 346 block
Stock Crank
Eagle H-Beam Rods
Diamond -2cc Pistons
ARP rod bolts
ARP head and main studs
Ported LS6 stage 1 PRC heads
Undecided on cam yet... Maybe EPP FI cam or GT-7 from Lingenfelter
Weiand Polished Aluminum intake. I like the one piece intakes better than the 3 piece FAST's when boosting. Just personal preference.
Obviously the supporting fuel system mods, clutch, etc...
Anyways, do you guys think that the shortblock/longblock will be good for around 12 or so psi and 600RWHP?
What CR should I be looking at running. Stock gaskets what head cc?
Thanks
Yeah, I know the stock block and crank are good to about 1000. The rods/pistons/rings/rod bolts are the weak links. I just plan on running this thing on pump gas so I'll probably try to stick around the 9 mark.
Yeah, I have an LS6 intake right now but I like the polished look of the weiand so I'll probably sell mine and go that route.
Thanks!
