AEM Tru boost
Old May 14, 2009 | 11:35 AM
52172's Avatar
Default AEM Tru boost
I have a 6 lb spring in my WG and am trying to run 15 lbs of boost, but it doesn't seem to want to go higher than 12 lbs. My duty cycle is from 10-90 and when I set it to 90 I can't seem to go over 12 lbs of boost. Do I need to run a higher spring in the WG to be able to get the tru boost to go over 12 lbs? I thought you could get it to go higher than double the spring pressure not sure though? thanks!
Old May 14, 2009 | 11:44 AM
lt170chevelle's Avatar
yeah not a 100 % hiv positive but i think double the spring rate is all you can get.
Old May 14, 2009 | 11:47 AM
hellbents10's Avatar
LS1Tech Sponsor
Usually you can only double the spring pressure with out using co2.
Old May 14, 2009 | 12:34 PM
DrTurbo's Avatar
LS1TECH Sponsor
Yes you will need to go up on spring pressure.
Old May 14, 2009 | 04:13 PM
52172's Avatar
I'm going to get a 10 lb spring to be able to raise it to 20 lbs if needed. Thanks guys.
Old May 15, 2009 | 08:20 PM
mike13's Avatar
Why can you only double spring pressure? If your controlling boost reference to the wastegate it seems like you could run infinite boost. I'm sure you guys are correct but can you explain it to me?
