re-using cometic head gaskets
Old May 18, 2009 | 11:07 PM
tirefryin_s10's Avatar
Default re-using cometic head gaskets
I did some searching but did not come up with much info, what do you guys use when re-using cometic head gaskets on a ls engine?
I am wondering what I should coat them with or any special precautions I should take.
Thanks!
Old May 19, 2009 | 11:44 AM
Anyone input?
Old May 19, 2009 | 11:46 AM
losiguy's Avatar
You can reuse them if they look MINT. If there is even one imperfection pony up and get new ones. Get all of the copper spray off them and re-spray. I've re-used mine 3 times (nitrous motor) with no problems yet. Some will tell you to do it, some won't. It may be different for Turbo/Blower so wait for a few more opinions.
Old May 19, 2009 | 12:40 PM
Smearin's Avatar
Too much hassle to tear back down if something is wrong- dont skimp.. pay the extra $$ and get some piece of mind.
Old May 19, 2009 | 02:00 PM
smokinHawk's Avatar
think i have had my heads off 4-5 times, same gasket also no coating, no leaking
should be fine as long as they arnt damaged.
Old May 19, 2009 | 05:37 PM
theblur98ss's Avatar
I paid the extra for cometics on my first big build so I could reuse them. When the time came I didn't trust them and bought new ones anyhow.
Old May 19, 2009 | 05:42 PM
180ls1's Avatar
i am not sure about the gaskets, but i sure would be mad if i popped a motor because i reused headgaskets.
Old May 19, 2009 | 09:31 PM
helicoil's Avatar
I have had no problems re-using Felpros or Cometics in a pinch, however if you can afford NEW I would do it. Seems kind of pointless to jeopardize a problem with all the work of removing the heads in these cars, but then again I guess money, or the lack of, makes those decisions easier.
Old May 19, 2009 | 10:16 PM
Engine is in a mustang so heads are easy to get off ... money is also uber tight right now.
