how to upgrade the procharger
Old May 19, 2009 | 01:13 PM
PONTIAC SLP's Avatar
Default how to upgrade the procharger
i have a procharger 6-12 PSI so i want to upgrade it to 22 PSI , how can i upgrade it and who can make it ?
Old May 19, 2009 | 01:14 PM
Gauge's Avatar
11Second Club
What kind of head unit do you have? What's the displacement of your engine? What kind of cam and heads? What kind of power are you pushing currently?
Old May 19, 2009 | 01:21 PM
the engine LS1 5.7 pistons 3.905 -9cc , eagle rods 6.125 , crank 3.622 , stock heads STD 241 , untill now we did't purchased the cam , what cam we should install ? and what LSA we should run with , and how we can upgrade our procharger to 22 PSI because the maximum we can run with our procharger 6 PSI
Old May 19, 2009 | 02:15 PM
Gauge's Avatar
11Second Club
What head unit do you have? To increase boost, you have to increase the speed the blower spins by decreasing the size of the blowr pulley. However, if you have a P1SC or even a D1SC most likely, you're not going to get 22psi out of it and will need to buy a new head unit.
Old May 19, 2009 | 02:49 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
The blue metal label on the blower will tell you what model you have.
Old May 19, 2009 | 03:13 PM
slothy's Avatar
ya at 20lbs better have some studs and a 6th bolt lol
Old May 20, 2009 | 05:40 AM
EPP's Avatar
EPP
I don't advise trying to run more than 16 psi of boost with a Procharger with stock heads. You need a thicker head deck so as the ones from AFR. Here is a link to my build, we saw 19 psi from an ProCharger F-1A on my 408. A smaller displacement engine with identical components would see even more boost. http://www.exoticperformanceplus.com...Car.php?car=12
Here is a link to our blower camshaft which we have in my Camaro.
http://www.exoticperformanceplus.com....html?item=679 Bob
